'36 Door panels and kick panels
Topsterguy
Has anyone got a pic or 2 of stock 36 Ford standard door panels and kick panels? I need the layout pattern for them. Thanks.
There are many different ones depending on the body style, interior material, and month of manufacture, you will have to supply more information about your car ---the 35-36 restoration book has drawings on most types
36 5 window standard coupe. I see in LaBaron Bonney the door panels are just materail with 4 sewn lines down same as my stock seat, but the are no kick panels shown.
I know the picture of the book page isn't too clear, but the stitching pattern shows, the more complex pattern is listed as late May
the cowl panel is listed as "brown fine colonial grain cardboard" ---changed in May to dark taupe fine colonial grain cardboard ---my Lebaron Bonney kit for my conv sedan has no stitching in the cowl panels
Thanks a lot, Kurt, that helps for sure! Larry
Larry, It sounds like you have an early to mid 1936 std 5 window coupe. Standard vehicles did not have carpet kick panels at the bottom of the door panels. Here are some images showing the stitch patterns and upholstery material for an early to mid 36 standard 5 window coupe.
Regards,
Don Rogers Author 1935-36 Ford Book
Regards,
Yeah that's mine for sure - I have the original seat and that's the pattern I'm having the seat, door panels, and kick panels done in a distressed steerhide leather, instead of the fabric, but I want to keep the same patterns throughout. The coupe is the one in my avtar. Thanks for the info! Larry
