36 distr.
GOW
I just got a nice 36 2dr. sweet running .....goes,stops everything works a nice body..........great little 36. I left the key on over night and now it won't start. I figured I burnt the points ....I've been able to get new points and condenser. I'm a long time car guy but have never worked on an early car with the dist. in the front of the engine. it looks like I have to take the gen. off and take the dist. out of the engine to replace the points......am I correct ?any tips? yeah I know DON'T LEAVE THE KEY ON........thanks
ACTUALLY IF I CAN FIND SOMEONE IN MY AREA THAT WOULD COME TO MY GARAGE AND DO THE JOB THAT WOULD BE GREAT....CASH PAY ,NO JERKING AROUND,.......I LIVE NEAR ALBANY,NY
you don't have to take the generator off, if you pull the sheet-metal pan just behind the radiator you can get to the bolts off. the key and the slot in the cam are offset, so the dist goes in one way. make sure it is firmly seated to the cam cover before you bolt it down. i second sending it to someone to go through it. the dist needs to be run on a Sun Distributor machine. you may have smoked you coil also Skip Haney can help with the Dist and coil good luck. i would come help you but i live to far away!...PS take your time these old Fords can be a Bugger
i would do it for Beer!
the original key/switch set up was replaced with a key switch and push button to start
thanks for all the good advice ......this mechanic stuff gets harder every year ...at 71 my dam fingers don't work like they use to and i'm always forgetting where the hell I put some thing...........:)
