J JunkyJud Member Nov 2, 2018 #1 I have a '36 LB that has an aluminum press on cam gear. The match marks aren't aligned perfectly but they are very close. The misalignment is probably about the width of the line. Will this create a noticeable problem?
Ol' Ron Well-known member Nov 2, 2018 #3 I always check for split over lap, wnen both valves are open at the same time at TDC. The may vary alittle but it works OK.
J JunkyJud Member Nov 2, 2018 #4 Thanks fellas. I figured that it would be okay but I wanted to check.
