36 cabriolet instrument panel
flathead47
Is the only difference between the closed car instrument panel & the cabriolet instrument panel the windshield crank hole.
Yes the windshield on the Cabriolet does not crank open, so no hole for the crank handle. Since the Woodie wagon has the same Windshield frame as the Cabriolet I would think the same applies. MrTexas would know for sure.
What Gary said. The closed car dash attaches with screws from the windshield opening that are hidden when the windshield is closed
Are the dash mounting holes in different locations. Does any one have a picture showing the cabriolet dash. The 35/36 Early Ford book shows & says very little about the dashs in these cars ..... Thanks
The top of a cabriolet dash is totally different in the way it mounts and in the ends that go to the molding. A coupe or sedan will not fit in a cabriolet or woodie wagon. The only way is cut the top off one and weld it to the bottom of the other. The dash for a coupe is a lot easier to find then a cabriolet dash. BW
