J Witt
My brake pedal had more free play (1 1/2") than I liked. The pull rod running from the pedal arm has a slotted, adjustable end fitting that is mated to the fork on the cross shaft with a standard clevis pin. I removed the pin and adjusted some of the slack motion out so the brake pedal has about 3/4" free play.
While doing this I noticed that the lever on the cross shaft has a second hole that is closer by about 1/2" to the cross shaft. Using this hole for the slack fitting makes the brake pedal move less and consequently will require more effort on the pedal and less motion to actuate the brakes. I put the system back like I found it, but I wonder if anyone has run their car with the higher effort setting, and which one is the correct hole?
I can't find a reference to this in any of my stuff or on the forum.
Thanks,
John
Thanks,
John
