A big thank-you to all who post. I haven't had much to add as everything I have needed is in the archives. My question through is which hole In the frame do you use to mount the rad on my 36-5 window.
Passenger car radiators used the set of mounting holes nearest the front cross member on 36 frames. The outer most hole was used to mount the pickup and panel delivery radiators. Pg 69 The 1935-36 Ford Book
