36 5 W Coupe Rear Window Regulator Spring
Gary Tosel
The rear window regulator for the 35-36 5W Coupe is almost the same as the right rear door window regulator for the Fordor Sedan. The main different is the handle for the Coupe has a threaded screw for the handle while the Fordor window regulator has a hole for a pin.
To Maverick1, the spring should be the same if you cannot find the original Coupe regulator spring.
Thanks Gary, I will check into that. I was at the turlock swap meet this weekend and found the a regulator,of course the spring in it was broken. I did get the telephone number of a gentleman who said he had one. Hopefully it works out.
Thanks again.
