Fortunateson
Not as interesting as other threads but here it goes...
I have a '87 F250 which came with a carb. Over the years the pollution stuff has been disconnected as well as parts have died. I had the original carb rebuilt a few years back but it always ran rich. A month ago I finally bit the bullit and had a Holley 600 installed. The shop I took it too regularly works on carb equipped vehichles. They installed the Holley and it runs much better. The throttle return spring is a bit heavy but I will change that.
Now for the advice... It is a bit of a struggle to get started. It sits for a week or more at a time and I pump it twice to activate the choke and to give it a squirt of gas. I may have to repeat this a few times bu eventually it runs at fast idle to war up. When I put it into gear it dies and I try again and eventually, though a little quicker, it runs. After about fifteen to twenty minutes of driving al is well. The shop removed the EGR when they installed the carb.
Any ideas/solutions? Thanks in advance!
