'35 window reg help.
madmak95
The new '35 5 window project I just got was stripped and in primer. So there's no window regs. I've been looking and have found out that the '35 and early '36 are what's needed. My question is will pick up regs work in my coupe?
I doubt it. PU regulator arms are different than passenger car. Can't remember right off which arms are longer, but I think it is the pickup.
madmak9s , This is what you need on your lower glass track ,you should have a thing like a large rivet this meshes into the thinga me slot you see in the end of this ,Ted
