35 weather stripping
drchip
Still trying to get this figured out - My window channel kit has separate pieces for the quarter windows (as opposed to the u shaped channel for front). I can see old stuff was screwed to the outside of the window opening but where does the inside piece go? To the garnish molding? Zero instructions in kit. Thanks
Woops - Just found a bag of clips I took off the garnish moldings back when labled "to hold felt on garnish molding"
Good luck, the clips thatcame with the kit for my 36 coupe did not come close to fitting. I wound up using some stainless #4 flat head sheet metal screws thru the fuzzy stuff and into holes I drilled into the garnish.
Those clips can be difficult to install and I made a 1/8" rod bent at 90 degrees and then with a pliers, installed the clips.
Hope this will work for you.
