Dennisfly
My door handle failed to spring back to the horizontal position and the door latch didn't extend to keep the door closed. I removed the two screws in the handle, the two screws in the jamb, and the screw under the door panel but I can't remove the latch because the square shaft on the handle is holding it in. How do I remove the handle and shaft and what do you think my problem in the latch mechanism is?
