rgtharley
Hello all,
Finally got the 37 motor I bought last year into my 35 Tudor, and ready to run. First, some history, this engine looks to have been a military rebuild from the 40's, all OD green, and fresh pistons, and a few new valves. Cleaned all the scale out of the water jackets and heads, bought two brand new water pumps from Skip, the 37 style that also become the motor mounts. I rebuilt the carb with a kit from Ken CT, sent the 35 distributor to Skip for rebuild, (which I have since moved the timing several times, so I don't know where I am now).
New wires, caps and plugs, but when trying to start the engine, only get intermitent running , and not real smooth. I saw some arcing from the plug wire tubes, and I'm thinking, the plug wires might be shorting enough to cause poor running. Is this common, and is it possible that I bent up my new wires so much by shoving them through the tubes, that they are shorting out? Is there an easier way to run plug wires if you don't care about the original appearance? By having center outlet heads, I found that the wire tubes won't bolt up to the intake manifold anyway, so I'm thinking about just using aftermarket type wire separators to hold the plug wires. I'm also thinking about sending my distributor back to Skip to time it again. After that, the only other variable would be the carb, and maybe I need someone smarter than me to make sure I rebuilt it correctly.
Thanks for any and all opinions!
Bob
Bob
