B-O-B
Try your local truck repair shop, if you can find one, to have the wheels & tires balanced on the car. I personally use the beads. I had a repair shop balance the front wheels on my F-500 as it had the death wobble at times & speeds. That didn't help so went to a tire shop to have the tires replaced. HUH !!! can you believe one rim was bent pretty bad & just by luck they had one out back in the weeds. Put it one & cured my problem.
