35 Sedan Horns and windshield crank
ferndog
I'm restoring a 35 tudor sedan and ready to reinstall the horns. My front fenders have holes in them for the wiring but they are in front of the horns, which seems odd. Wondering if this is correct or if it should use the bolts with the hole thru the middle for the wiring to run thru. Can someone please confirm how the wiring runs thru the fender?
Also, is there an escutcheon that goes on the dash behind the windshield crank?
Wish I took better notes when I took her apart.
Thanks.
Yes there is a escutcheon behind the window crank... A tricky devil to find if you don't have one
Ferndog, I know you had sent me messages requesting pictures of horn mounting and wire-up. I had taken pictures but forgot to send them to you so I'll post them here.
