35 Radio install question
35topdown
I'm putting a 35 Ford Phaeton back together that someone else took apart from the frame up several years ago. Could someone please tell me how the radio antenna lead is routed from the radio through the firewall. I assume that it goes through the firewall, but I can't find a dedicated hole. I believe that it then follows the frame rail back to the spare tire, although some have said theirs is routed under the running board. I'm at the stage of installing the new wiring looms and new interior. Any tips will be appreciated.
Richard
On my 35 roadster I run it under carpet along left edge to spare tire,which is isolated from body.
Richard, Heres the installation sheet that might help you. It notes that in the 35/36 cars the antenna lead stays inside the car between the floor board and mats/carpeting.
