I need a set of 35 pu original gauges. also, can these gauges be adapted to 12 volt. what about the senders for fuel and oil. I cant find any of the modern gauges that I like. thanks steve
Baxter Ford Parts is usually a good supplier for gauges. They made both single and dual gauges in 1935. The fuel gauge was not electric in 1935. If you want to run an electric fuel gauge, you could run all 36 gauges and speedometer so that they would all match and all fit the dash openings.
