That's the same as on my 1931 AA. Wrap the gasket around the
glass and pull it fairly tight so there are no puckers at the corners then cut the rubber so he ends butt. Remove the rubber from the glass then Super Glue the ends together, I let is set a few days, then reinstall it on the glass. I put the seam at the top, then install in the cab.
