Replacing a fuel pickup unit without cutting metal or removing the fuel tank can be tricky, but it's not impossible. Here are a few suggestions:
Check for Access Panels: Sometimes, there are access panels or removable sections in the floor or under the rear seat that can provide better access to the fuel pickup unit.
Use Flexible Tools: Consider using flexible tools like a flexible pick-up tool or a flexible inspection camera to help you reach and manipulate the fuel pickup unit from the opening.
Consult a Professional: If you're unsure or uncomfortable with the process, it might be best to consult a professional mechanic. They might have specialized tools or techniques to perform the replacement without cutting or removing the tank.
Look for DIY Guides: There are many online forums and guides that might have specific advice for your vehicle model. For example, some Ford truck enthusiasts have shared their experiences and methods for replacing fuel pumps without dropping the tank.
