VeryTangled
’35 Mechanical Brake Rod Shape Question
Hi Everyone, While crawling under a '35 car, I observed the brake rod in the attached photos. (At least one other brake rod on this car was similar.)
My question is about the straightness of the rod. I see a 'Z' shaped profile, instead of a straight line.
My experience with these rods on our '36 is that you need to have as close to zero bends in them as possible. When they are bent, and you're trying to transmit force from pedal to shoes, the rod will flex at the bend, and reduce the force, correct?
In the spirit of having a lively but civil discussion... What comments do the 'Barn'ers have about what I've seen?
