35 ignition part question please
ssrcobra
Does anyone have a picture or dimensions of the retainer that fits in with the toggle switch? I also need dimensions or pictures of the ball and spring that fits under the screw.
Any help is much appreciated.
Thanks
The ball is easy 3/16" , hardware store, The spring 0.180 OD, 0.032 wire Dia., 0.300 Long, there are about 4.5 convolutions, I believe Roy Nacewicz sells these plus the lock washer for under the head of the cap screw.
The retainer ,I believe, is Ford P/N 48-3736 , your going to have to make one, or find one. Basic dimension is 1.200W x 1.429L x 0.050 Thick steel.
Here's an exploded view of the assembly done by Gary Tosel a while back plus another image I have showimg the screw cap spring and ball. Hope it helps you.
