35 front brakes on 32-34 spindles
roddyb34
Just seeing if I can put 35 type front brakes on 32-34 spindles ,,,also is there a difference in 36 spindles ,,,? Thanks from Rod ,,,
G'Day Rod,
There is a difference between '35 and '36 spindles.The spacing between the tie rod holes on the '36 LH spindle is wider by about a 1/2 inch and the spindle length is around a 1/4 of an inch shorter than the '35 one . I'm not sure about the brake bits fitting though.
Thanks for that ,,,I had seen that the 36 type are slightly different ,,I am after a set of 35 RHD ,,so I hope I can recognise them ,,,regards Rod,,
Rod, you can put the '35 front brakes on '32-'34 spindles but you will need the spacer normally used for a juice brake installation.
Rod, I got mine from MT Car Products and they're called
1928-1934 Front Spindle Adapters, $20 plus shipping for the pair.
