I have a 1935 Ford. The taillight does not work. I ordered and received a new cable connecting the wiring, joined to a longer cable from the front of the car. I bought a new bulb and taillight socket with wire for a 1935 Ford coupe. Our test then showed 5.8 volts. When we put the bulb in, nothing happened. The voltage dropped to nothing. What are the possible problems to check? Attached is the metal ‘washer’ that surrounded the old bulb socket, that I didn’t reuse.
Thank you.
Thank you.
