35 ford headlight hold down bolts?
Time-Bomb John
Does anyone reproduce or make the long bolt that holds the headlight pot to the fender brace and has a hole through it for the wiring? I can't seem to locate anything. Thanks I'm told they are not available.
You could always slice some 36's and add a piece of tubing to give you the length you need....
I have a pair of each but unfortunately don't know which im going to use yet, to offer you the others.... sorry
That custom might look good with some lowered stands anyways, you know ;)
Try www headlampsbybill.150m.com I met you at the l.a. roadster show. Went to your house with john walton.
Dan W
I have quite a few OEM bolts that had the hole in them for the horn wire that were used on the 35-37 pickups. If that is the same as the ones used on the 35 passenger and 36 passenger cars, you can email me at scardilla77034@yahoo.com and I can geet some to you.
I've already chopped the stands 1 1/4 inches and I am using 36 Buick headlights. I had to graft the inner support of the 35's to the Buick pots. Any pics??
