'35 Ford Coupe tail light lamp
hey Ateek29,i'd like to hear how those little alum.cupcake liners work for you,if you do try them. after what Mart talked about doing to his tailights and when going to grocery store and not finding that same little pan i found the cupcake deals that made sense if you look at alot maybe all modern auto tailight reflectors you will see many dimples/faciting in the reflectors.which those little cupcake liners acomplish. Tom.
Here's Henrys', and the story. And thanks for asking to see the photos. Henry's will never be restored, as the story tells the reason. There's a lube sticker on the door that I couldn't upload the pic. In 1968, it had 6,888 miles. Now....7,400.
  • Ford Story Booklet for Local V8 Club copy.pdf
Finally. The right bulbs to get. And a great tip on making that 6v bulb a little brighter. White paint and or cupcake foil! Thanks all.
473184
473185
473186
hey Henry Carl, you shouldn't need to paint inside of tail light buckets if you use cupcake foils because the foils totally surround the bulb. Tom.
Thank you for the pictures, That is in amazing shape for 86 years old!
I can see why you don’t want to change anything.
I needed some inspiration to get busy on mine. :)
