35 Ford coupe door glass adjustment
dono50
The top of the glass is inboard too far and I can't see any adjustments. Any help appreciated. Thanks in advanced
Not sure I understand your problem? The "cat wiskers" are what is supposed to keep the window centered between the garnish molding and the door frame. If the glass is hitting the top of the garnish molding maybe the molding is bent. It should lay "flat" on a level surface????????????
