The 35/36 lower door weather stripping attaches via the concealed spring clips that secure the door pads. The stock door seals had elongated holes in the rubber to allow for misplacement of the clips on the door pads and/or the holes in the door.
The seals are normally attached to the door pad then to the door.
I did wonder as the elongated holes in the rubber lined up perfect with the door card holes, but didn't think it could be mounted behind the door card.
When mounted to the door, does the rubber seal against the scuff plate on the body?
