I'm trying to remove the front brake drum on a 35 ford with mechanical brakes. The drum will not come off so I'm trying to remove the backing plate with the drum on it.
The backing plate four 4 nuts have been removed and the brake arm disconnected. The backing plate is loose but seems to be hung up on the brake operating pin which goes through the top of the king pin to the brake wedge.
There seems to be no way to remove the backing plate as this pin would first have to be removed.
Seems like it would be difficult to remove the pin with the drum and brake shoes still on the backing plate.
The question is can I somehow remove the backing plate with the drum and shoes still attached ?
