35/36 Brake Shoe
Bob56
Planning on working on my brakes but I ordered shoes before taking anything apart. This is what I got. Does it look right for 36 club cab They have the woven material
If you are still running stock, mechanical brakes, I would highly recommend woven lining. I would have it arc ground to fit your drums if that service is available in your area. This has been discussed many times on the forum. Everything in your picture looks correct.
Yes the backing plates appear correct and should fit original 36 front or rear. There is a second backing plate that is cast iron and not stamped steel, they are usually found on 35 vehicles but will also work on 36.
