34 wheel/tire combo for roller
Dr, no, (dr no ha ha) they are later type drums and hubs, which are unusual in that the drum fits inside the hub. That is not an adaptor plate, that is your hub. If you want to run wires you need a spacer as mentioned.
To answer your original question, any ford wheel 40-48 will fit and pickup wheels up to mid 60s. fords are 16"ers and the pickups are 15s or 16s. These do not need a spacer as they are designed to fit a flat face hub.
Mart.
You might also find Suzuki Sidekick/Chevy Geo Tracker wheels at the local scrap yard. 5 on 5 1/2 also Jeep CJ maybe Cherokee, but not Wagoneer .
Ahhh, I see now that I have tired to put a wheel or two back on.....spacer is needed to center the wheel on the “hub” and provide the support.
Smaller than any wheels with tires, '28-'29 21" rims without tires did the trick for me. The ones I have (only a pair) are really rusty and beat up but on a hard surface, they do roll.
