hudson1948
1934 21 stud V8 completely rebuilt including new cylinder heads. Ran beautiful, did not run hot. Put on a couple hundred miles. Then #2 cylinder on left side went dead but no noise, pulled head and oil pan found broken connecting rod. Now I can not turn engine. Broken rod did not damage anything. I do remember seeing abnormal condensation coming out of breather pipe. There are traces of water in oil. Does not look like water was getting into combustion chamber, piston rings on broken rod were not stuck. When engine was running there was no sign of condensation or anti freeze smell coming out of tail pipe. Didn't unbolt connecting rods yet. Any ideas of what happened or where condensation in crank case was coming from. Thanks in advance.
