Assembling a 34 transmission from scratch an need to know the correct direction of the synchronizer. There is a small flat on one side and none on the other. Does the flat face toward engine or to the rear. See picture. TIA
Here are two pictures of '36 transmissions that I have (same/similar hub as '34) that have not been taken apart. Extended part on hub is going to the front on these, same as you show in your picture.
Walt...you're right and you're wrong. MAG's original pic shows the straight slider splines of a 32-35 mainshaft. JM 35's example pics are the '36-39 variety, but he was just using them to show an example of the '32-38 style synchro. As my brother once said to me.....just nod yer head in agreement when your wife says she's right.....life will always be good.....
MAG,
Just a quick thought here....ignore if you are reusing the orig parts....if
however you are replacing some components be aware that there are two different
early style syncro sleeves , clusters and input shafts. The difference is in the width of the sleeve and gears . Email me if this is your situation, or get Mac Van Pelts
book.
Charlie ny cas5845@yahoo.com
Walt.....you've probably forgotten more than I'll ever know about flathead V8's, so don't feel bad. I just happen to go to sleep each night with visions of transmission gears dancing in my head.....
