34 toe board for passenger
My3window
Can any one tell me if there is a diagram available for the shape and dimensions of a 34 toe board for a passenger car. I have a wood shop and would like to make one if I can. I understand from previous links on this site that the toe boards were 3/4" thick and were coated with a combination mixture of tung oil and black enamel.
Thank you,
Tom
I think it is one piece and goes from door to door. I think you can just measure the area and cut. There might be some holes to drill and slots to cut. I have a store bought one and have not looked at it for a couple of years. I think it is from Sacramento Vintage Ford. I thought by the time I bought a 4x8 sheet of cdx plywood, broke a saber saw blade, cut the cord on the circular saw, sawed the steel saw horse, and patched the holes placed in the wrong place it would be cheaper to go store bought.
Try Roy Nacewicz. He makes the best one. He also has all of the seals and the correct finish and the kit with the correct bolts. Perfect fit!
