34 sterring problem
mike37cdn
i have a 34 stock motor and stock steering someone put in a drop axle and juice brakes looks like 40 backing plates and it has the adapter for the drag link what this has done is put the steering box of center and i can,t get the bow set upright is there a fix for this out there for this it does not turn as far one way than the other what i can see with the new piece for the drag lick puts in the wrong spot i can adjust box with the drag of and its good with no play put the stock drag link on and it puts the box of center and there,s play in the wheel thanks mike
Hi Mike,
You are absolutely correct. The aftermarket steering arm adaptors are not made correctly and you will wind up with the situatiion you have.
One suggestion is to replace the original '34 drag link with an adjustable drag Link so you can center the steering box when the front wheels are in the straight ahead position.
Contact Richard at the Early V-8 Garage, (626) 338-2282. He may be able to help you with the parts you need.
Just a suggestion,
I think you may have better luck with your thread in the Early V-8 Section.
Chris
