34 RH drive steering sector assy
A 35 sector is essentially a right hand 34 sector. I think I still have a NOS one. Use a 35 worm.
The fact that the '35 sector does not carry the '32-'34 BF-3575 part number suggests that an important difference exists such as the alignment of the splines on the end of the sector for the sector arm. If those splines don't line up exactly as originally designed, either right or left-hand turns will be compromised. The use of a '35-'36 sector arm would not necessary correct this problem. (This would apply to either the early '35 sector without the cotter pin hole on the threaded end or the later '35 sector with the cotter pin hole.)
