34 pu windshield hardware
j32
Hi guys, I was looking for some info. on the slide hardware for my windshield. I need to order most everything , the slides , knurled knobs , spacers and washers, and then there's the screw and tube nut, not sure where these go, the bracket that's on the windshield frame itself is threaded (12-24) and I believe a screw go's through the hole in the slide and threads into the bracket , don't know about the tube nut.
Thanks - Joe
All the parts are the same as 1930-31 Model A Coupe/Tudor/Pickup except the stud.
Most of the parts houses show a sleeve nut and screw for mounting the slide to the windshield bracket, that is actually 1928-28 practice (different bracket on windshield) or allows for a easy patch of a damaged windshield bracket or just discard the sleeve nut and use the screw.
