Hi,
I'm having a bit of trouble understanding how to set the end caps of the track rod and drag link ends on a '34 ford.
The rod ends on these models feature a removable cap that has one ball seat on, while the other ball seat is spring loaded.
So question is, how far or how tight do you fasten the cap down? ?It seems that unless the spring becomes coil bound then there will be some 'spring' in the links, or is this intentional?
None of the service literature I have even gives this a mention.
Thanks,
Mike
Thanks,
Mike
