34 fordor owner
Hello, I have another forum going right now pertaining to updates on my 34 sedan that I’ve been slowly getting back on the road. I was sure the cooling system was going to be serviced at some points but it was going fine. Today after a short trip down the road and back I noticed there was water and cooler all over the bottom of the engine as it had blown from the radiator. Both bottom hoses are not leaking, no leaks from the top hoses and the radiator it self looks fine. In the picture the most water seems to be directly under the radiator. Sort of near the over flow hose. I also noticed some dirty water near the over flow hose. My theory is 2 options: 1) there’s is a radiator leak at the bottom tucked away where I can not see or 2) the water is not flowing correctly and coming back I it the over flow hose and emptying out the bottom in good amounts. No water seems to leak while at idle I’ve only noticed this after a drive down the road hitting about 30. Any idea or has anyone experienced something like this. Next time I have a free moment to work on it I plan to drain the radiator and flush it and check more leaks.
