34 Ford Pick up
Would someone be so kind as to tell me if 34 Ford Pick Up Truck Front and Rear fenders are any different then a car. If they are the same what body style rear fenders fit. Thanks
The Fenders are way difference than a 34 car,You can use 32 car fronts ,They (trucks ) have a raised piece over the cross front member rivets, You can use 32 car rears with modifications
You can not use 32 car fenders on a 33-34 pickup. 33-34 frames has a bow in the top of the rail and a 32 frame top of the rail is flat also the front crossmember rivets stick up and the 32 front crossmember the rivets are flat and do not stick up. As for the rears 32 truck fenders ar different than 33-34 . Don't see how you could use car fenders at all.
