34 ford engine removal
looking for pointers on pulling a flattie and trans from a 34 ford.
Do I need to pull the radiator for removal and do you take the driveline out together or seperate.
pointers on the clutch and brake pedal removal
Also any other info its my first time doing this on this era car, I dont want to hack her up when I pull it.
Any info will help
I take them out[36]is same. And leave the ****** and drive line intact.You must support the trans before pulling engine or will drop quite a bit.I can lift out over the grill on 36 with boom 1/2 way out and clear by about 1". No need to remove grill do remove rad and all you can on front of mtr. Only my way of doing it OMO.
Remove the hood, Remove the radiator and grill as an assembly (the grill is attached to the radiator). Remove the radiator support rods and unhook everything from the engine.
You can remove the engine without the trans, just be sure to support the trans. Then you can remove the trans. I also believe the engine and trans will come out together.
That is what I would do.
Chris
you need to pull the grill then take out the radiator
