34 Ford Coupe Door
Boxcar
Sesser
Il
Price
450.00
For your consideration, 34 Ford 5W passenger side coupe door. If you require additional info please msg me. I am listing this door for my father who is located in So. Illinois.
Height at center: approx. 45 3/4
Width at beltline. 32"
Width a widest point of door. 37"
Information on the door: This door has had repairs to both the inside and outside lower regions, right to left. Lower third, exterior is replaced metal that was completely butt-welded (to the above area), dollied, lightly filled, and primed. Entire door was sandblasted, inside and out. Nason primer was used during the restoration. Light amount of body filler was used in the repair. Lower interior structure is replaced metal and was both tack welded and finished welded for the repair. Lower interior panel repair does not conform to original stepped design. The repairs were accomplished without a "Test Fit" car SO it was a dead reckoning repair result that may/or may not require future adjustment to fit your car. I can attest that the repairs that were made were done with quality materials and workmanship that will stand-up to use. Please let me know if you have any questions. $450 plus shipping or local pick-up
