Tom does not have a web site. Just had a chance to go check, the floor panel has the correct raised areas, it is the sub-rail that does not. Me being somewhat lazy and the fact that the floor is covered, I just cut the area out of the sub-rails to fit. I also weld the pieces together vs spot welds. Again to me it is covered and I'm not attempting exact reproductions. But if you want it to be correct, it is fairly easy to add the dimpled area to the sub-rails. There are additional issues with the sub-rails, there is a hole missing that is required for the 5-window coupe at the rear door pillar. Again a very simple fix. They also require a few small cuts and rewelds to get the curve to match like I want. So, the point is, these are fairly good repo parts, but they do require some modifications if you are wanting exact replacements.
