Feathercraft56
So I have a 34 Ford Deluxe, still 6v system. When I apply the brakes the headlights flicker and die out, releasing the brake the flicker and return. I’ve replaced lighting harnesses front and back, ran extra wires soldered to headlamp grounds and ran to frame. Good light sockets and brake switch has been ruled out as well. I feel I’ve done everything possible but the issue still persists. Has anyone ever had this issue? About to replace under dash harness, only thing left to change. Rebuilt generator and. The only part not new is the fuse block with resistor. And no there is nothing being pinched by brake pedal.
