34 coupe wood bow brackets
tintop
Riverside
California
Howdy all, Im still looking for the small metal brackets that tie the wood bows to the bottom of the roof trough. I dont have these for my build, (in fact Im not even sure what they look like really). If anyone out there even had 1 that I could use as an example, that would be great! please pm me if You can help out:) Thanks! tintop
For 34 there are no brackets, 33 has them. There are tubular nuts attached to the inside bottom of the tack strip and the bows slide over these and then 1/4-20 bolts attach the bows to the nuts. The bolts each have a rectangular metal washer that is bent to the radius of the bows. at the ends of each bow is a small metal tack strip screwed to the bow and the door or Q-window wood header for attaching the headliner.
