JimG
I was suddenly having trouble with my clutch not wanting to totally disengage. Felt like something broke, as it came on suddenly. I took the car to a guy Charlie ny recommended, as I thought I was in for taking the clutch out. Turns out the pin that holds the clutch lever to the shaft coming out of the bell housing had broken. This is part number 352581-S off the enclosed diagram, but the diagram is for a 1935 car. Does anyone know what the original diameter of this pin would have been for a 1934 car, and what the material would be? The shop where I have the car said they have reinstalled a 5/16" hardened bolt in place of it. Said what was left of the old bolt looked like 1/4", which wore and eventually broke. Should I be concerned that using a hardened bolt (don't know if he is using Gr 5 or 8) would cause more wear on the linkage arm and shaft. If it is going to wear, it would be better if the bolt wears. They probably wouldn't be too happy if I asked them to change it to a regular bolt at this point. I only drive the car 500 miles or so a year, so maybe it doesn't make a lot of difference, but you do use the clutch a lot in normal traffic.
