34 Clutch Grease hose
Ed Solari
The hose that goes from the top of the bell housing to the clutch throwout bearing and forks. It provides a path for lubing the assembling from the top of the transmission(small cupprotrudes out the top). Who makes repo? ... or at least the fitting at the ends of the hose. Mine is worm out and it seems that MAC, C&G, and Dennis carpenter dos not make these. Thanks
ed, i believe i have a N.O.S. hose and fitting assembly. send me your e-mail and i`ll send you some images so that you can confirm that it is the correct hose for your application.
tom
why worry about it ford did away with it in 35 guess the did not think nessary just put a grease inside the collar like me do on 35-48 cars . leave the plate with the fiting & who will know.
