BobWatts
I've been working on getting my Dad's 1934 Cabriolet running after sitting for 22 years and was just about to try and fire it up when checking the head nut torque a stud spun.
So I've pulled the heads using a plate I made (if you're interested here's a video- https://youtu.be/1o2x-4o4MSs ) to put a heli-coil in and sent the heads to a local head shop where after cleaning 20 years of built up crud out they milled them flat again.
They say it took 18 thousandths off in the process and recommended I get a thicker head gasket and that's where I would greatly appreciate a little advice.
I've heard of bolting on the heads and gaskets and then using putty of some sort to check the head to piston clearance.
Is that where I should be headed? Some where else? Thanks in advance!
