kgriff
Having problems with a 34 3window that's windows are not working properly. Car has had a vintique glass channel kit installed, has one original regulator, one aftermarket regulator, one aftermarket metal window channel and one metal window channel that supposedly was original to car. Aftermarket metal channel has been made to match the "original". However, neither of the metal channels measure the length (I've found here on the Barn) of 26 11/16". Both are 25" and don't have the 3/4" off the front, upper glass channel has been cut flush with lower roller channel. How critical is it they be 26 11/16" long ?
Thanks in advance.
Thanks in advance.
