Hello, I new to the barn, so please bear with me.
I have A pile of T Items that I want to make into a fun driver. Kind of like early "rat', if you will, speedster.
My first question is that I have adapters for my hubs to take model A wheels. Can these be used with later wheels. "33 or "34? They will work with the bolt pattern.
If they can be used, what kind of problems can I expect?
MANY THANKS FOR YOUR HELP.![]()
i thought that was for the other message board, the one with the non-ford cars with slightly not correct parts.You may try introducing your self. As per rules.
Well i guess one problem you might have is low gearing with those wheels. If you use a fairly lightweight body and want to go faster you could use the 3:1 gears in the rear axle without a problem (lightweight being not a 4door hardtop or delivery van).
