highbeams
To fasten your 1933 V8 grill emblem:
Explanation: The entire 1933 grille, including the nickel-plated surround is one-stamped piece. Between the top of the grille and the top of the radiator, there is a permanently-fastened center bracket around the radiator cap. Through this centered-bracket there are 2 fine-threaded machine screws. There are also two fine-threaded machine screws on the sides of the radiator midway one on each side. Also one fine-threaded machine screw on each corner, one fine-threaded machine screw adjacent to each headlight and each horn.
Remove these all screws to access the back of the grill in order to attach the V8 emblem. 11/32nd fine machine thread.
Replies welcome. Removal of the grille took us awhile to figure out.
Replies welcome!
Replies welcome!
