Brian, You are missing a vital point here. If you have a six volt electrical component and you apply 12 volts to it then you will double the current flowing through it. Its like a water pipe with a flow of 10 gallons per minute at 10 PSI applied, if you double the PSI (pounds per square inch) pressure applied then you double the water flow. Yes a 12 volt system will only require half the current in amps for a given wattage component than if that component was in a six volt system. Brian, study up on ohms law to have a better grasp of it all. All automotive electrical components are designed to operate on their correct voltage and not double that voltage. By doubling the voltage you are breaking the design rules. Regards, Kevin.
